BSRV6
I'm New Here
I'm looking for a checklist for a RV6. Looking for a pre-flight, emergency fire and emergency engine failure, before landing, after landing, and shutdown checklists. Also, anything else that anyone might think of. I will be doing a check ride for my private in the near future and would like to have something to show the examiner. Thanks so much for the help!
Welcome to VAF!
Search is your friend, plug in CHECKLIST first, then POH and start clicking and reading. For instance, here's a thread that even I posted in, so it must be good! :D
Good luck on your PPL!
The checklists you referenced need to be specific to your RV-6 because each -6 is built and equipped differently. Somebody else's checklist may give you a starting point for developing your own checklists, but I doubt if your check pilot would be very impressed with checklists that are not applicable to your aircraft. If you want generic checklists they are available at vendors such as Sportys.
Best wishes for a great checkride and congratulations in advance on your new ticket!
Go to the homepage, click on poh's in the left column, click on the third rv6/6a in the list, scroll down and all the basic checklist and procedures are listed in the poh. I adapted this one for my plane.
RV6A checklist
This is my checklist. It is a work in progress. It is customized for my plane. Yours is almost for sure different, especially the avionics and electrics. It was formatted so as to print double sided and then trim to 5x7 and laminate. The appropriate emer. items were in RED Send me an email and I will send you the Word.doc file.
PREFLIGHT INSPECTION
1. Cabin
a. Documentation???..ONBOARD
b. Charts???????.ONBOARD
c. Control Locks????RELEASE
d. Master Sw. ?????ON
e. Flaps ???????..DOWN
f. Fuel Quantity????.CHECK
g. Fuel Pump ????......ON
h. Engine Gascolator??..DRAIN
i. Fuel Pump ????......OFF
j. External Lights??...?.CHECK
k. MASTER SW??..?...OFF
2. Left Wing
a. Flap ????????CHECK Security
b. Aileron ???????CHECK
c. Pitot Probe ?????..CLEAR
d. Wing Tie Down ???.DISCONNECT
e. Main Wheel Tire ???CHECK 32psi
f. Chock ???????.REMOVE
g. Wing Tank ?????..SUMP
h. Fuel Quantity ????..CHECK
i. Fuel Cap ??????.SECURE
3. Nose
a. Cowl Hinge Pins ???SECURE
b. Propeller and Spinner ....CHECK
c. Nose Wheel Tire ??...CHECK 32psi
d. Chock ???????REMOVE
e. Fuel Tank Vents ???CLEAR
f. Air Inlets ??????CLEAR
g. Eng Oil ???????CHECK 6-8 Qts
4. Right Wing
a. Wing Tie Down ?.??DISCONNECT
b. Main Wheel Tire ???CHECK 32psi
c. Chock ???????.REMOVE
d. Wing Tank ?????...SUMP
e. Fuel Quantity ????...CHECK
f. Fuel Cap ??????...SECURE
g. Aileron ???????CHECK
h. Flap ????????.CHECK Security
5. Empannage
a. Right static port ????CLEAR
b. Tail Tie Down ????...DISCONNECT
c. Control Surfaces ????CHECK
d. Left static port ??.??..CLEAR
STARTING ENGINE
a) Mixture ?????RICH
b) Throttle ?????? Travel OPEN
c) Master SW ???...ON
d) EIS Warnings ??..CLEAR
e) Fuel Boost Pump ?.ON
f) Prime ??????1-3 STROKES
g) Fuel Boost Pump ?.OFF
h) Nav Lts ?????.ON
i) Strobe ??????ON
j) Propeller Area ?.?CLEAR
k) Engine ?????..START
AFTER START
a) Oil Presure???? 25PSI Min
b) Flaps ??????.UP
c) Volts ??????.14V
d) Avionics Master ??ON
e) Transponder ??? ON
f) Fuel in EFIS ??? SET
g) Flight timer ???. SET
BEFORE TAKEOFF
a) Brakes ??????. SET
b) Flight Controls ???.FREE
c) Flight Instruments ??SET
d) Trim ???????.GREEN LT ON
e) Fuel Selector ????HIGHEST TANK
f) Mixture ??????RICH
g) Throttle ??????1800 RPM
a. Mags ?CHECK (200 RPM max drop)
b. Suction ?????..?5?Hg
c. Engine Innstruments ?.CHECK
h) Throttle ?????...IDLE
i) Radios ?????.?.SET
j) Fuel Boost Pump ??.ON
k) External Lights ???SET
l) Canopy ?????LOCKED
NORMAL TAKEOFF
a) Flaps ???..UP
b) Throttle??. MAX
c) Rotate ???60Mph
d) Cllimb ???85-125Mph
e) Boost Pump ?OFF
f) Lights ???.As Required
SHORT FIELD TAKEOFF
a) Flaps ???..10o
b) Throttle ??..MAX
c) Brakes ???RELEASE
d) Climb ???.75Mph(Vx)
e) Flaps ???..UP
f) Climb ???.85-125Mph
g) Boost Pump ?OFF
h) Lights ???..As Required
CRUISE
a) 75% Power ?2450 RPM
b) Lean ???..125o Rich of Peak EGT
c) CHT ???..435o MAX
Below 75% Power:
a) Lean ??.Peak EGT
b) CHT ??.400o MAX
c) 65% Power 2350 RPM
BEFORE LANDING
a) Fuel Boost Pump ??ON
b) Landing Lights ???ON
c) Fuel Selector ????HIGHEST TANK
d) Throttle ??????1300 RPM
e) Flaps ???????? (100Mph Max)
f) Flaps ???????Full (88Mph Max)
g) Approach Speed ??..75Mph + wind
AFTER LANDING
a) Boost Pump ????OFF
b) Landing Light ???..A/R
ENGINE SHUTDOWN
a) Parking Brake ???..SET
b) Flaps ???????DOWN
c) Throttle ??????IDLE
d) Flt Time & Fuel ?.......CHECK
e) Avionics Master??...OFF
f) Mixture ??????.IDLE CUT-OFF
g) Master/Lts??..??...OFF
h) Ignition ??????.OFF
SECURING AIRCRAFT
a) Master ???????SW OFF
b) Chocks ??????...IN
c) Canopy ??????..LOCKED
d) Pitot and Intake Covers .INSTALLED
Loops/Lazy Eights??.. 140 to 190 mph
Immelmanns ????.. 145 to 190 mph
Aileron and Barrel Rolls .120 to 190 mph
Vertical Rolls ???? 180 to 190 mph
Split-S ??????? 100 to 110 mph
AIRSPEEDS FOR EMERGENCY OPERATIONS
Engine Failure After Takeoff:
Wing Flaps Up ???????? 85 Mph
Wing Flaps Down ??????.. 70 Mph
Maneuvering Speed (Va) ???????. 115 Mph
Best Glide ????????????? 85 Mph
ENGINE FIRE DURING START
Cranking ? CONTINUE, to get a start which would suck the flames and accumulated fuel through the carb and into the engine.
If engine starts:
1. Power ????? 1700 RPM for a few minutes
2. Engine ????? SHUTDOWN and inspect for damage
If engine fails to start:
1. Throttle ????.. FULL OPEN
2. Mixture ????...IDLE CUT-OFF
3. Cranking ???? CONTINUE
4. Fire Extinguisher .. OBTAIN
5. Engine ???.?.. SECURE
ENGINE FAILURE DURING TAKEOFF RUN
1. Throttle ?IDLE
2. Brakes ? APPLY
3. Wing Flaps ? RETRACT
4. Mixture ? IDLE CUT-OFF
5. Ignition Switch ? OFF
6. Master Switch ? OFF
ENGINE FAILURE IMMEDIATELY ON T/O
1. Airspeed ? 75 Mph
2. Mixture ? IDLE CUT-OFF
3. Fuel Selector Valve __ OFF
4. Ignition Switch ? OFF
5. Wing Flaps ? AS REQUIRED
ENGINE FAILURE DURING FLIGHT
1. Airspeed ?85 Mph
2. Boost Pump ? ON
3. Fuel Selector ? SWITCH TANKS
4. Carb Heat ? ON
5. Mixture ? RICH
6. Ignition Switch ? BOTH, LEFT, RIGHT
7. Transponder ? 7700
IF ENGINE WON?T RELIGHT
8. Mags __ OFF
9. Master __ OFF
10. ELT __ ON
11. Airspeed __ 85Mph
ENGINE FIRE IN FLIGHT
1. Mixture ? IDLE CUT-OFF
2. Master Switch ? OFF
3. Cabin Heat and Air ? OFF
ELECTRICAL FIRE IN FLIGHT
1. Master Switch ? OFF
2. Avionics ? OFF
3. All Other Switches (except ignition) ? OFF
4. Vents/ Cabin Air/ Heat ? CLOSED
5. Fire Extinguisher ? ACTIVATE (if available)
CABIN FIRE
2. Vents/ Cabin Heat ? CLOSED
3. Fire Extinguisher ? ACTIVATE (if available)
WING FIRE
1. Nav Lights ? OFF
2. Landing Light ? OFF
ELECTRICAL / ALTERNATOR FAILURE
1. Master Switch ? OFF, (LEFT HALF)
2. Avionics ?OFF
3. Alternator Breaker ? RESET
4. Circuit Breakers ? VERIFY POSITIONS
5. Master Switch ? ON
If Alternator Is Still Off-Line:
1. Alternator Master Switch ? OFF (Left half)
2. Batt Master __ ON (right half)
3. Unneeded Avionics ? CBs Pulled
4. Light Switches __ As Required
5. Alternator Breaker ? PULL (60amp)
6. Electrical Equipment ? ON, as required
7. Back Up Batt ___ ON, When Required
8. Flight ? TERMINATE as soon as practical, aircraft is on battery only.
AVIONICS BUSS FAILURE
1. Avionics Buss Master Sw. __ OFF
2. Alt Avionics Buss Master Sw (red guard) __ ON
