Ryan Koontz
I'm New Here
I am in desperate need of a RV4 rt hand fuel cell in good shape or new. I talked to one guy about building one and he wanted 2K. I cant pay that. Anyone have any ideas? If so, give me a shout at [email protected] or 8502070309. Thanks. ryan
The problem that you will have is that since the 4 is not pre-punched, any tank that you buy will not really fit. the holes will be off and the fit will be just a bit different. The only real solution is to build a new one to fit the aircraft.
bob burns
RV-4 N82RB
can be done
you can have someone build your tank but it will have to be final fitted and drilled on the aircraft.
I just built a new right tank last fall. it actually fits better than the original tank..
CM
