I purchased a RV-3 that does not have spots to tie down the aircraft when parked outside. Where is the attach points on the plane suppose to be located?
The should be drilled into the extrusion that provides an anchor for the aileron bellcranks. Check to see if you have some open holes just forward of the inspection covers - they would be to screw in tiedown rings. If not....Hmmm, retrofitting might be tough.
