The part numbers are F-14188B-L&R, F-14188A and AV-50003 which is the face or the power module.
FWIW, I was going to use this for my fuse box as it is designed for but since it will add more work for inspection area, I changed my mind.
As a glove box, it should be much less work to remove it in order to get to the tunnel for inspection and work.
