Can someone help me with detailed drawings (top view, side view) of the 14 to start playing with paint schemes? There is something on the RV14 Vans website yet is quite crude.
I've made/reworked a line drawing from a CAD file supplied by Van's. I'm using Autocad to generate a PDF file that I convert to a PNG file afterward. This allows for replication of identical drawings having exact same dimensions from one another.
The file I'm generating produces a very high resolution print if you have the mean to print it out to full size (44in x 34in or 6750 x 8750 pixels). Otherwise, you can print out at a reduced scale if necessary. If you PM me, I can send you two files showing side and top view. I can send in PDF format or PNG.
As an example, see below a down sized file of one of the paint scheme I've created. It is 1600 x 700 pixel
Check with Username: Notorious Nate. He's been working on a paint scheme for my 14 for awhile, and has made all the 2D views and a 3D model. He does great work, shoot him a PM.
