DanNiendorff
I am scratching my head and need to consult the collective wisdom of those who have gone before me.....
I am working on the tailcone, installing nut plates which will be later used to attach the empennage fairing and gap fairings to the longeron.
Ref Page 10-20
1) The image and text say to rivet 5 of the 7 nut plates which attach to the longeron. These 5 nutplates will attach the gap fairing later. The two forward nut plates are not shown to be riveted. These forward two nut plates will attach the empennage fairing later. I see that the two forward nut plates are used in section 12 to install the empennage fairing - and appear to already be present.... but I don't see anywhere that those nut plates are specifically instructed to be installed. Is there a reason not to install until some later point?
2) The image shows one of the five nut plates with a single CCR-264SS-3-2 rivet. Am I correct to read this as indicating that the CCR-264SS-3-2 is an acceptable substitution rivet for the AN426AD3-4 used in all the other nut plate holes here? I don't see a reason why a cherry rivet would be used right now where there is good access.
Any insight from someone who has carried through to the empennage fairing attachment would be helpful.
-Dan
Ref Page 10-20
-Dan
