TimO
Has anyone found the source for the proper lighter socket that goes between the front seats on the RV-14. With the pre-punched hole it kind of forces you to use just the right socket. I just spend almost $40 on the one from SteinAir because it looked at least similar, but it's a no-go. Without getting the proper one, it'll leave an ugly appearance where you see the primer painted under-frame...and even if you paint it to match, it's still an unsightly hole. So I'd like to find just the right accessory jack that Van's designed it for. I don't see one on their website.
I guess I could also ask about the entertainment jack or whatever goes in the square hole, but I do have a music jack that fits reasonably well there.
12V Power Socket
I think this is the one for the RV-12. (maybe the same for the -14?)
ES AS212 12V POWER SOCKET $6.50
