Soarandtow
Active Member
As per the instruction the dim should be on page 7 of the drawings but I can seem to find it.
I have the rudder mounted and I am very pleased with it.
Just want to compair the plans to what I have and see why I can't find the info on my plans
Thanks all
I see the rod end dimensions on DWG 7, LEFT SIDE VIEW. The dimensions are from the bearing center hole to the face of the spar. It is noted with Revision 2 which "added dimension..." dated 1/12/01. For me these dimensions were close and a good start but I had to make some minor adjustments, a half turn or so to get it all lined up nicely. The drawing shows the top one at 51/64, middle 63/64 and the bottom 1-1/16.
