GKnut
Member
Have a question regarding the last 3 or 4 rivet holes on the rudder's tip and bottom ribs. They need to be dimpled to accomodate the 426 rivets. Problem is that the dimple die will not fit in the narrow space behind them. Is it allowable to countersink them, given that they are .032 in thickness? If not, what is the trick or work-around?
Input would be much appreciated for this grommet builder.
