A friend who spends lots of time upside in his 7 posed an interesting question the other day. During some manoeuvers your feet can slip off the rudder pedals and the cables go slack.
Now imagine a large rudder deflection - maybe due to lots of yaw or a tail slide . Say a screwed up wing over. The rudder cable could lodge itself on top of the rudder stop.
Playing with Ken's machine in the hangar it certainly seems easy for it to get stuck on top. When this happens the cable end fitting prevents centering of the rudder and you are stuck with permanent rudder deflection. You could get it back on the runway but it wouldn't be pretty.
Has there been a documented case of this happening or is all this hypothetical?
Internal rudder stops would make this potential problem go away.
