F FNG Member Feb 6, 2019 #1 I just bought a RV-9A. It has an O-320 A2B and three bladed Cato FP prop. The rpm at 55 knots on takeoff roll is only 2150RPM AT 10*C and 1200 pressure altitude. Is this normal? I?m not certain it is developing full power. Thanks.
Michael Burbidge Well Known Member Feb 6, 2019 #2 That?s about my Static RPM. Full throttle, brakes holding the plane in place. But I have a 160 HP O320.
L lr172 Well Known Member Feb 6, 2019 #3 Michael Burbidge said: That?s about my Static RPM. Full throttle, brakes holding the plane in place. But I have a 160 HP O320. Click to expand... I would expect someting in the neighborhood of 2150 RPM static, but would expect it to be a bit higher at 55 knots. If you cruising at 8000' what is the max RPM WOT and ROP? Larry
P PCHunt Well Known Member Sponsor Feb 6, 2019 #4 I'm sure Larry meant to specify 8,000' DENSITY ALTITUDE.
