At the same speed, the -7 should give you a better ride with the higher wing loading. However, one doesn't build a -7 to travel at -9 speeds, right?
I notice a HUGE difference in the CT when I go from light (9 lb/sf) to heavy (13 lb/sf) after picking up fuel and a passenger in the same stop. However, unlike the -7 vs -9 comparison, that's not changing the span or airfoil, just the loading and CG.The friend of mine really likes to fly at fuel conservative speeds in his 9. So when I fly along, I'll sometimes pull back to these these "tortoise" air speeds too. And even though my 6A has a higher wing loading, it just doesn't make a noticeable difference in turbulence. So we can throw the theories out, based on actual experience.
L.Adamson --- RV6A
(snip) The 160 hp RV9 wing loading is not that much different than other two seat RVs. Rough air handling should not be a major factor in selecting RV models.
But not much as power increase requirements is exponential. So the 20-40 HP increase in the 7 doesn't buy a lot of speed.7 also allows larger power plants thus speed
Humm, use a little math and physics to answer the questionAs it concerns a smooth ride, that is a function of inertia. A heavy object will be more resistant to change in motion than a light one. So both airplanes -7 and -9 should have very similar ride characteristics.
You do get a lot more of that rolling motion with a long winged / high aspect ratio airplane. I find that quality admirable in sailplanes (e.g., Duo Discus, 20m / 66ft span); good for helping sniff out thermals.The longer wing, when upset, creates a bit more roll.
The wings are only a foot and a half longer on each side. not very much. May not be very noticeable. The wing loading is very similar also (RV9A=14.1 lb/sqft RV7A=14.8 lb/sqft). Any difference may be more likely attributed to the higher lift generated by the 9's high lift wing.The longer wing, when upset, creates a bit more roll....
Marshall,
I think the difference was probably the prop. I gave a friend who is a CFeverything some left seat time in -9 prior to the first flight in his -7. Later I asked him which was easier to fly and he replied the -9 was much harder to land. He credited that to the CS Prop in his -7 with the difference.
Below 150, the ride is similar to a Cherokee at cruise, above 150 it feels "sharper."
