SeanB
Hey Everyone!
I purchased and installed a Showplanes Remote Oil Cooler mount that resides aft of cylinder 3. This makes you relocate the baffle opening for heater scat to another spot. Mine is now behind cylinder 4, where the stock oil cooler would mount. The firewall SS heat box (already installed) is now aimed the wrong way for this. Has anyone ever rotated this box 180 degrees to get the inlet facing toward #4? It appears the bolt pattern will not be symetrical when using the existing 2" hole. The control cable just needs swapped to the other side behind the firewall. Any pics would be great!
BTW..Vetterman cross over exhaust, no mufflers, vertical induction.
Thanks.
