N546RV
So last night I rolled and riveted the leading edge of my rudder. I really wanted to pull down the vertical stab and temporarily assemble the two together, so that I could stand there, flap the rudder around, and grin like a madman. But it was 11:30, and my helper had abdicated for the evening.
As a kind of consolation prize, I decided to at least thread in the rod ends as a gesture of sorts. I was surprised when I threaded in the lower one...it went in a few turns and then bound up pretty tight. So I moved on to the other two, and got the same results; a few turns in, and then things get really tight.
Having had some bad experiences in the past that resulted from strong-arming threaded fasteners, I left things alone and quit for the evening. Well, almost...I had this horrible fantasy that there were two similar, but not identical, types of nutplates in the kit, and that I'd installed the wrong ones and thus done a real number on my rudder. A quick look at the parts list disavowed me of that notion. Whew!
As an experiment this morning, during some downtime at work, I strolled out to the garage, pulled out a spare K1000-6 nutplate and a rod end, and tried to thread the two together. Same result, a couple of turns and binding. (I had thought that maybe, somehow, assembling things might have deformed the nutplates a bit. Another kind of wild idea, but these are the things that go through my head)
So...has anyone else run into this? Is this expected? Do I need to run a tap through the nutplate or something? (I don't really like that thought, since it would likely end with bits of metal floating around in my rudder)
I know I don't really need to worry about these things for some time, but it would certainly help my peace of mind.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
