the4ork
Member
here is what my dad and i have done so far, its not much to look at but this is the trailing tail spar and elevator hinges...
Tail Jig... when i start riveting the ribs on... and rivet squeezer behind it, alot with the rest of the parts on the shelves
my models i have hanging... and the mood lighting lol
gotta have lots of the best tools... dewalt drills are awesome since they have my last name on them :p
no affiliation tho... but good for non-pnuematic drilling
a little QC..
Looks like you might have a couple of holes with less than ideal ED -- possibly where the center ribs rivet to the aft spar -- or are those simple pen marks? If those are holes, can you confirm 1/4" edge to center?
Loads are kinda high in that particular area (center hinge bracket)....be careful!
Also: we recommend using the elev spars to place the pivot brackets on the spar (F1 elev spars are pre-drilled). You will have to go thru this process backwards to be sure the elevs will actually fit your H Stab -- so measure carefully, after you drill the elev horn to the spar, and bolt this sub-assy to the center pivot, with the correct washers in place. Fit the tip ribs at this point, also.
I can fix you up with directions on a few F1 style mods if you're interested.
Carry on!
Mark
that would be great...
we made an error... accidently drilled a hole for the hinge bracket before fitting it, after fitting the bracket the hole didnt line up, so there were two holes right next to eachother that were connected = bad
so we reordered the parts to start over again :mad:
