Currently I'm taking the very first baby steps in my project -- I've built the toolbox, I'm practicing riveting with some scrap metal (old computer cases), and I've got HS-609PP just about ready to go.
Now, with that said, I have some questions.
I know somewhere out there, someone has to have explained how to properly use a pneumatic squeezer to set rivets. I set most of the rivets in my toolbox kit with the squeezer, and most of them look fairly good. So far, so good.
Here's the problem-- I oversquoze some of those rivets, and in the end I have no real idea how I'm supposed to have done it better.
How do I properly set the gap in the squeezer before I squeeze a rivet?
I understand how to actually manipulate the gap, but what I don't understand is how to figure out what the gap should be before just 'squeezing a rivet and seeing', which seems very wrong. The instructions that came with the squeezer talked about setting the gap to the total length of the squozen rivet, or something to that effect ... but I'm really not sure what that would be exactly.
So, that's the squeezer. The rivet gun I've been having less consistent results with. Some unevenness on the shop head if I screw up the bucking, obviously -- I'm sure that'll go away with practice.
The problem I'm having is that I have the swivel adapter, and when I try to set a rivet, the set tends to move a fair bit. I sometimes end up with a rivet that's not actually in its dimple but is protruding out a little bit, with a slightly deformed factory head.
I assume that too will go away with practice, but it's not going away quickly. I don't (And won't!) have a helper for riveting, so I was wondering if there was anything in particular that I'm specifically doing wrong... if this symptom sounds familiar.
Thanks in advance fellas! :>
-Fox
-Fox
