redwoodcstrvr
Member
This is my first posting. I'm assembling the empennage for a RV-9A and looking at the possibility of annealing the rivets before installation. I have talked with RV builders who have used this procedure on each of the airplanes they have built and all were very pleased with the ease of driving this type rivet. Their annalogy was "it's the difference between slicing butter right out of the refrigerator and butter that was at room temp". The key to proper annealing is temperature control, time at temperature and rapid quenching. I have the tools to do this. The one builder I have talked with has even accomplished a series of destructive tests and found that the strength of the rivets after annealing were equal to or better than the Alcoa stats. I know that Van does'nt recommend any change in procedure or modification to his kits primarily for potential litigation issues. Would really appreciate any input pro or con.
