small tip great results
One other thing you can do to help is dimple the under structure, (ribs) to receive the skin dimple. This means if you use the same dimple dies on the skin as the ribs you will inherently have proud rivets. The top skin's outside is 100 deg and the back side of the skin is 110 deg. So when you dimple the rib the top is 100 deg and the back side is 110 deg's. Then you put the skin on the rib and the interface is thus: skin 110 deg trying to go into a 100 deg hole, add a little pro-seal and the rivets will be proud as a cat covering up in a flower bed!
Try this: make the rib dimples 110 deg on the top surface. Do this by one of these ways.
1: thin material (.032 or less): use a small piece of aluminum that you leave on the male dimple die. this mimics the skin, at times we super glue this piece on the male dimple die. This will pound out after several hundred dimples so you will need several handy.
2: thick material (.032-.040): dimple with your regular dimple dies, make sure you have completely dimpled the hole so hit it twice or three times with the c-frame or twice with the pneumatic squishier. Then using a 110 counter sink true up the dimple.
3: for heavy material (+.040); just use the 110 deg counter sink.
