Howdy,
I am riveting the wing ribs to the spar (RV7a) using an offset rivet set. The manufactured head is on the rib-side of the assembly, and the shop head on the spar (as is specifically called out in the instructions).
The issue is simply this: My offset rivet set tends to "turn" in the rivet gun as I'm riveting. This has caused all sorts of "smileys" adjacent to the manuf-heads of the rivets I have attempted so far. Has anyone else had this issue? Any easy solutions?
I did a quick search of the forum archives, but couldn't find a similar post - hopefully this is not a duplicate question!
Thanks!
Thanks!
