Hi,
I came to the point where I have to rivet my first skin, the vertical stab skin to the front spar assembly. The instructions tells you exactly along what lines you should sequence the riveting.
But based on your experience should I do one side, close it and then flip over. Or should I rivet few and then rivet the same rivets on the other side and move on?
