ijustwannafly
I know there are many techniques for this and Wirejock has mentioned a nice one to me also. However i was curious. Say for some idiotic reason you wanted to squeeze them. Has anyone found a longeron yoke large enough to get around the flange of the main spar?
I thought about a 3 inch alligator squeezer but doubt that would work either.
More just a curiosity question. I will most likely end up using the dreaded offset set and doing it the normal way but is there something out there i wonder!
long straight rivet set
I didn't use the "dreaded offset rivet set" to attach the ribs to the main spar. I used a 12" long straight set. You can push the rib sideways a bit to clear the rivet gun.
