Jstov
I don't know if you guys have seen this or use it but I find it very useful. It is an app on iTunes that helps you figure out what size to use. You simply put in the thickness of the material and what type of rivet and it gives you the correct size. Search rivet sizer on iTunes it works and is real easy! Sorry Apple devices only!
Figured
I knew I was behind the curve on that one but I just wanted to share with everyone in case they did not know about it.
