cyberpilot10
hello all
I am working on the VS attaching the bottom rib's to the front spar. Once again the enemy of good enough has bit me in the butt. I drilled out an an470 rivet in the corner and had to put such and angle on the drill I elongated the hole. should have left the first rivet alone. I put a smile in the top by not letting the rivet gun stop before I pulled it away. so now that the hole is messed up, as soon as I start to shoot the next rivet it starts to bend over. I have a set of oops rivets from Avery but none of them are Universal head...any suggestions would be appreciated. Not to mention the marks I had to file out from the drill chuck hitting the rib flange.....man I should have left that first rivet alone....
![9i9t20.jpg](/community/proxy.php?image=http%3A%2F%2Fi44.tinypic.com%2F9i9t20.jpg&hash=7f6e960dae81c12c391edc945dd6c418)
