rapid_ascent
Hi Folks,
So I've been working on my practice kits with some success, getting ready to take the plunge before too long I hope. I had a couple of problems, not major, but I was hoping someone could point me in the right direction.
I was trying to setup my rivet gun that I purchased on Ebay. It's supposed to be an Avery gun so I think it is a quality gun, and as far as I can tell it is. I wasn't sure what pressure to set my compressor to so I saw a video that Cleaveland Tool had that said to set it a 90 PSI. When I did that it seems to really smash the rivets. I do have a regulator on the gun, but I couldn't seem to get that to work very well with such a high pressure. When I reduced my compressor down to 50-60 PSI my gun seemed to work OK. I saw a thread that even had lower pressures. Not sure if the regulator on my gun is just not working. It seemed very sensitive when had 90 PSI from the compressor and I couldn't get good results. I also found that my drill wanted higher PSI so it was a pain leaving the compressor set at the lower PSI. I was eventually able to drive rivets sucessfully, but I may need some help here. Any ideas on the correct way to do this would be helpful.
The second problem I had was with my flush set. I had a standard flush set and I decided since I was a beginner that I should buy one of the swivel type with the rubber cup. I was able to use the basic flush set without any problems, but I was never able to get the other set to work right. It seemed like it wasn't contacting the rivet. Like maybe the rubber cup was preventing the set from hitting the rivet correctly. I thought I remember something about sanding these flush but I'm not sure. Any hints on using these I couldn't get it to work.
