Hey way not
You know you could call the manufacture, I did once.
I called about the cool little remote electronic compass they made, but discontinued. I called and they where helpful.
This compass has to be as good as a WWII airpath design. May be draw backs are:
Weight?
Magnetic Dip? As you know, with what looks like a bigger card it may "swing more", but that only comes into play during turns and acceleration and deceleration.
Cost? The boat stuff is not free, but $40 is a bargain. The real heavy duty serious large compasses cost....well........ a boat load. :eek: :D
George
George
Pretty Cheap
Hi George,
I did call them - $39 online. Should fit in my empty 3-1/8 hole too. Has compensators and can be repaired if required. Friendly people.
Seems like a good risk.
I bought something similar from the boat store during the early interations of my panel. It had absurd amounts of error when in the plane. :(
Anyway, I have the remote compass on the D10A now and have no regrets going that route. :D
compass
Hi Pete:
I think you'll find that locating a compass in the panel can lead to large errors. It might be possible to find a location that has minimal magnetic deviation, but it may be sensitive to electric currents from adjacent wires or instruments. You won't know until it's too late to change.
I have the type that mounts to the windscreen support. I chose the location by using a handheld compass, and finding the point that had the least deviation. For a bunch of reasons, the steel in the roll bar and support are slightly magnetized, and it's best to find the neutral point before installation.
When I swung the compass, I ended up with a maximum 1 degree of error throughout 360 degrees... which is probably as good as I could align the aircraft on the compass rose. The Dynon EDC and the compass agree to within 2 degrees.
Vern Little
Final inspection complete - no snags. As soon as the interim C of A is issued, I can fly.
