I purchased a set of wings that already had some work completed on them and while i was mocking up the right tank i noticed that the hole drilled for the vent line was not per the plans.
[/URL][/IMG]
In the picture above you can see the mark where the hole should be drilled and the hole below it from the previous owner. I think i have 3 options here:
1. Use the hole for the vent line and just bend the line to fit it.
2. Put a provisional fuel return line in case i need it in the future and drill the vent line in the proper place.
3. Plug the hole...not sure what i would use in this case, however.
Any suggestions?
[/URL][/IMG]
![IMG_20161215_180709029.jpg](/community/proxy.php?image=http%3A%2F%2F%5BURL%3Dhttp%3A%2F%2Fs1207.photobucket.com%2Fuser%2FThoma015%2Fmedia%2FRV-7%2520Tank%2520Build%2FIMG_20161215_180709029.jpg.html%5D%5BIMG%5Dhttp%3A%2F%2Fi1207.photobucket.com%2Falbums%2Fbb464%2FThoma015%2FRV-7%2520Tank%2520Build%2FIMG_20161215_180709029.jpg&hash=9bad50646bc96c005c4edb9f68c2e955)
Any suggestions?
![IMG_20161215_180700035.jpg](/community/proxy.php?image=http%3A%2F%2F%5BURL%3Dhttp%3A%2F%2Fs1207.photobucket.com%2Fuser%2FThoma015%2Fmedia%2FRV-7%2520Tank%2520Build%2FIMG_20161215_180700035.jpg.html%5D%5BIMG%5Dhttp%3A%2F%2Fi1207.photobucket.com%2Falbums%2Fbb464%2FThoma015%2FRV-7%2520Tank%2520Build%2FIMG_20161215_180700035.jpg&hash=fc7207abcf50ea9050b3e7f0de92f644)
