Tom Maxwell
OK, I am not instrument rated so don't beat me up too badly. But I have been flying on instruments in flight simulator 2004. A typical flight goes like this:
I set up my flight plan direct from airport A to B.
I contact clearance delivery and usually hear, "N123AB, cleared to B as filed, fly runway heading, climb and maintain XXXX, contact ground on XXX.XX, clearance void 30 minutes from now."
I taxi to the active, contact the tower, and take off into the muck. Pretty cool!
I get handed off to departure and get vectored to a course that parallels the GPS direct track.
During this process I typically hear something like this: "N123AB turn right/left heading XXX, cleared to XXXX, Resume Own Navigation."
In IFR terms what exactly does, "Resume Own Navigation" mean? Does it mean I can deviate from the assigned course to get onto my GPS direct track? Or does it simply mean that I need to take responsibility for tracking my flight progress? Or maybe it means something entirely different.
I guess I need to get some IFR knowledge test manuals.
"Own Navigation"
Generally, "resume own navigation" means they are no longer vectoring you and you can fly your filed (or cleared if they have amended it) flight plan.
In practice, it means you go direct to the next waypoint in your flight plan. If the vector has taken you well off course, they will frequently clear you direct to a subsequent waypoint so you don't "zig-zag." e.g. "Resume own navigation direct BINGO then as filed."
If flying a Garmin 430 with the flight plan entered, and flying a heading with an S-Tec autopilot, the key sequence is Direct-Enter-Enter (on the Garmin) and Nav-Nav (on the S-Tec). Takes about half a second ;-)
James Freeman
Literally:
RESUME OWN NAVIGATION- Used by ATC to advise a pilot to resume his/her own navigational responsibility. It is issued after completion of a radar vector or when radar contact is lost while the aircraft is being radar vectored.
Now if they give you what you said, "N123AB turn right/left heading XXX, cleared to XXXX, Resume Own Navigation..."
That heading is probably a heading more or less direct to that fix, right? After that fix, like the flyeyes said, you're cleared on the route given to you by clearance delivery until you reach your clearance limit. They will generally drop you off somewhere that makes logical sense along your route - if not, ask!
Say Again? Unable?
cool!
GPS direct track.
You will hear resume normal speed, resume own NAV, often after ATC has given a speed or vector (heading) clearance. Many times this is for separation of other aircraft.
When given vectors you just fly a heading ATC gives you. It is easy. ATC is
responsible for your NAV and separation from other planes and terrain if you
are IMC. (However don't let your gaurd down and follow blindly.)
>"In IFR terms what exactly does, "Resume Own Navigation" mean?
different."
Don't get DIRECT, RESUME OWN NAV and GPS mixed up.
First if they are giving you direct own NAV chance is it's a VOR. GPS/VOR
is not relevant as long as its an IFR GPS. Unless you file that you're equip
includes an IFR GPS, ATC should NOT give you direct to a way-point out in the middle of no where, not defined by a VOR. As you know if all you have
is a VOR the only way to navigate direct (TO/FROM) is a VOR, unless you
have AREA NAV (aka, RNAV). Bottom line a VFR GPS is not usable for "OWN
NAV" in the IFR world. (It can be used to cheat in some scenarios.)
If they give you direct XYZ to a way-point (not a VOR) and you don't have
an IFR GPS or RNAV you can't accept it. However if they say VECTORS
direct to XYZ turn left/right heading 123, VOR or not, you can use a VFR
GPS to "help" you get there and monitor your progress as a backup. ATC
has to say VECTORS.
A VFR GPS is a no no as OWN NAV, but OK as a back up to vectors. If it's
a VOR and you are in the "service volume" and above "MEA" or MOCA" than
you use your VOR.
>"During this process I typically hear something like this: "N123AB turn
Remarks on above, not sure that's totally correct (ATC guys help). The
"resume own navigation" is clear, you will fly the "flight plan route" with
your on board radios (VOR/GPS). They will usually "clear you" to fly the
flight plan route. The words own NAV comes after they have vectored you
off the flight planned route. In the example above the words VECTORS
was not used and assumed you where already own NAV.
When "vectors" is said, that is the heading you fly and you stay on.
Remember they may be giving you separation from other aircraft; they
may want you to get to XYZ but NOT direct. XYZ is mentioned so in
case you loose communication you know the next way-point you are
cleared to.
In the example you give you a say heading but no vector, it's only a HELP
to get you turned in the right direction, and even if they did not say own
NAV, it is assumed unless stated otherwise. They will usually also say
"direct". The could just say direct XYZ, flight planned route. The heading
is just help to point you in the right direction.
>"I set up my flight plan direct from airport A to B."
A flight plan is made up of Departure, transition to enroute (or SID),
enroute, transition to approach (or STAR) and approach. Sometimes the
transition to and from the airway are one and the same waypoints. The
most simple example would be two airports with a VOR on them, you
takeoff and climb over the VOR on the field, which is on a "airway" to a
VOR that's on airport "B" and where VOR "B" is the transition to the
approach (or the VOR approach). A simple VFR direct a/p to a/p flight
can get complicated to define and file IFR. In practice in the real world
after takeoff you may very well be cleared direct. However you also
have to file so you can fly it with no ATC help, since that could happen
with radio failure right after take off. In theory if IMC you fly all the way
to the destination airport and fly the approach (at or after your ETA).
You really can't FILE direct airport to airport unless there are VORs on the
field. We fly NAV aids not airports. A IFR flight plan is based on airways
(VOR's) and waypoints (intersections defined by VOR/VOR or VOR/DME).
Now with GPS you have GPS or Area NAV waypoints only, but only if so
equipped. It gets more complicated if the airport is VFR. The best you
can do is file to a IFR airport near by. Think of it like coding computer
programs. It has to be in the proper nomenclature with valid data so
the path is defined exactly.
Airports are filed as departure and destination not way points. You flight
plan may end at a way point that defines the initial approach fix to the
one of the airports approaches.
(* There are local ATC airport direct programs but they are really based
on getting vectors for ATC. I think SO Cal has these "preferred local
airport to airport direct programs.)
Remarks on above. Not sure that is totally correct (ATC guys help). The
"resume own navigation" is clear, you will fly the flight plan route with your
on board radios (VOR/ IFR GPS). They will usually say "cleared to destination,
flight plan route". The words "own NAV" comes after ATC has been giving
you vectors off the flight planned route. When vectored you JUST fly the
heading. ATC is responsible for your NAV (but don't just blindly trust with
out cross check). In the example above the words VECTORS was never
used. I would think they might say, Radar contact, 5 miles east of XYZ, turn
left heading 270, direct XYZ, fly flight planed route. There would be no
"own NAV" since that's assumed, but I could be wrong. If they said "Radar
Contact 5 east of XYZ, turn left to 200, vectors for traffic, expect direct
XYZ"......"RV123, turn right 300, direct XYZ, flight planned route, resume
own NAV. That means heading 300 is approx direct, but you fly it as
needed. )
None of this will make true sense until you do it. Read the AIM/FAR sections
on ATC communication, IFR regs and pilot to controller glossary. I have to
admit when I was starting out IFR it was a mystery. +10,000 hours later,
the IFR system is still a mystery sometimes. There are hard and fast rules
and than some grey areas and interpretation in what happens in the real
world. Bottom line is safety and for the little guys to stay out of the way
of commercial jets. That sounds arrogant, but as both a little guy and
airline puke, ATC/IFR rules are to separate little from big commercial aircraft.
90% of the airspace is for IFR. VFR pilots will understand airspace better
if you understand it is to protect IFR traffic for VFR traffic. Also ATC
instructions often are to protect the pilot from lost COM, meaning in the
event you loose your radio you have a plan to get you to the destination
or VFR conditions, what every happens first.
Hook up with an CFI and pilot who works for the FAA as a controller. (Several
ATC guys are RV'ers.)
As the previous poster stated, if you don't know ASK. ATC makes mistake,
pilots miss hear, ATC mis hears read backs, so on and so on. When in doubt
ask.
George CFI/ATP
Turn to XXX
Turn to XXX and proceed to XXXX making whatever changes in heading that are necessary to get there (cross wind corrections, etc.). The rest of your clearance is unchanged. As long as XXXX is on you cleared flight plan every thing is fine when you get to XXXX turn to the next point on the flight plan. If not you have a discontinuity in the flight plan, request clearance to proceed direct to the next point in the flight plan you can't assume the controller is aware of the ambiguous situation - especially if there has been a controller change. If you lost communication squawk 7600 and just do it with necessary MEA altitude changes and broadcast intentions and position fixes in the blind with appropriate frequency changes as you follow your cleared flight plan. You are expected to continue to your destination - save yourself.
Bob Axsom
hmm..
I was flying VFR one time and had flight following and there was big section of class B airspace right between me and my final destination.
I was cleared into Class B, and was flying along at about 1000 ft above the Class B shelf, and received a vector to fly that was (I assume) for traffic. After a bit, ATC said "Resume Own Navigation" and at that point I said "Roger, Decending 1500 ft and squaking VFR" because I wanted to duck out of the Class B space.
Then ATC came back on and basically yelled at me saying "I didn't clear you to descend, etc..."
Soooo... moral of the story... resume own navigation also means "AS LONG AS YOU MAINTAIN ALTITUDE" (I guess).
I'm not IFR rated... so how would I know...
-Clay
Excuse meeee!
I'm not IFR rated... so how would I know...-Clay
Should have not yelled at you obviously. You did nothing wrong, except you should have "requested to descend to 1,500 ft and sq VFR". I guess he assumed and expected you to stay at current altitude. IFR your altitude is so00 critical and controlled even when on own NAV; you never leave an altitude without permission. You where getting the IFR treatment. You told him what you where going to do. The most he should have said was, "NEGATIVE, remain at #,### and stay with me for traffic", or something like that. However your point is correct, NAV is horizontal, unless they say something typical like, descend at your own discretion, which is common. G
In IFR terms what exactly does, "Resume Own Navigation" mean? Does it mean I can deviate from the assigned course to get onto my GPS direct track? .
This instruction is usually given after an ATC vector that (temporarily) takes you off your originally cleared route. It means resume navigation; 1) with your own equipment; 2) upon reaching the specified fix to which you were vectored; 3) on your originally cleared route. So no, you can't deviate.
It lightens the comm load
When I used to fly to work every morning in the Los Angeles area I would often be given the direction to "Resume own navigation" after the first vector to intercept victor 8. Unless there was a potential conflict, the next time I got a call would be around the time I intercepted V363, when I would be directed to contact the controller in the next sector on 125.5 mHz. Ocassionally I had to call to remind of the frequency change - it was a busy place and you can be forgotten.
Bob Axsom
Usually in socal at least, "resume own navigation" is used mostly for VFR traffic. IFR will normally get "as filed" which really means the last of cleared, expected, or filed in that order. So it'd go like this:
My clearance out of POC:
Cardinal 3295T Cleared to Santa Barbara, climb runway heading to 1400' Left climbing turn hdg 130? to intercept the Pomona 164? radial, prato, V16, PDZ, V186 VNY DEANO, V27 KWANG. Climb maintain 4000, expect 6000 10min after dep... and so on.
Once in the air, departure almost always turns you directly onto V186, instead of sending you to PDZ, so it'd go something like this on the first contact with departure:
"95T Turn right heading 320, intercept V186 as filed" which just means "do whatever you were going to do before you were told to do this" :).
Vfr
the other day (since some SoCal guys are on here) I'm flying my Cessna 140.
Departed Riverside Muni and going West.
I got a Vector and then, "Resume own navigation-- but remain clear of CNO class D and ONT class C airspace.
I was scrambling for a chart and figured I had to go all the way south over Corona to avoid Chino and Ontario.
I got queried as to what I was doing.
I going to go grab a chart right now to figure if I missed a corridor or something.
I was just thinking that the title of this thread would be an excellent name for a plane, regular magazibne column or a first born child!
:D CJ
