Karetaker
Howdy everyone. The small lines that run from the restrictor fittings on the engine to the fuel/oil sending units: do these need to be bled to remove air?
For reading oil and fuel pressure, it is actually better to have air in the line if the sensors are mounted above the source. But it really doesn't matter.
