A300Driver
Active Member
Documents
What documents are required on board an experimental?
Bob
Bob
I know this an old post but just curious. There are several RV's that fly to Mexico an the Bahamas. Do you have to have a Radio Station License for those occasional flights?
I read the ruling and it appears it maybe required. At approximately $100 for the license, it sure would be nice not to have to get one for occasional international flights.
Can anybody cite the reference that requires that "weight and balance" data be carried in the aircraft? I was always taught that it was required but a very experienced ATP rated pilot stated that the only requirement was "that weight and balance had to be calculated for the flight" period. Was he referring to Part 121 or Part 134 rather than part 91 flights?
...For international operations (other than Canada), you will also need an aircraft radio station license. This can be obtained from the Federal Communications Commission (FCC). For more info on the aircraft radio station license, see the following web site:
http://wireless.fcc.gov/aviation/
Roberta
