roadrunner20
I'm looking at replacing my 12LS starter with the NL.
Has anyone replaced the NL on a Superior IO360 with the forward induction?
Any gothchas replacing it? I'm outside of my home base & have limited resources.
SkyTek originally said they would cover the LS under warranty. but has since reneged on it. I figured it would be a good time to swap it for the high torque model.
Dan,
While my airplane isn't a vertical induction, I replaced my LS with the NL and it was a great upgrade. Very strong starts. Any reason you aren't considering the B&C starter instead of the NL??
Dan,
Hey Mike,
Thanks for the feedback.
Sorry we won't be enjoying the Beer tasting this year.
I may consider using the B&C, as it appears to be sized closer to the LS. B&C is priced $145 higher than the NL. Quality is probably superior, but the SkyTek had worked for me since 2006.
I have a Superior IO-360 with horizontal induction and cold air sump. When I fit my snorkel I had to cut off the two lower "Accessory Attachment Points" on the Skytec housing, which is allowed by the manufacture. A hacksaw and deburring material take care of the job, but painful to cut into a new, unused starter.
Are you referring to points B, C & D, need to be ground down to the case?
