I know that bird well.. i owned it before the current owner, did the paint and panel years ago. Good airplane, flies straight and fast. It had two new wing tanks built and installed when the cn-1 and cn-2 wing mods were done. The catto prop is pitched for cruise. Th panel pic is before the fuel flow cube was calibrated. It was burning 7 gph in that pic. The airspeed indicator pic is WOT, 1000ft agl and trimmed out max speed indicated. I never got around to calibrating the static ports, but it should be pretty close. It is a fantastic flying airplane. I thought about buying it back, but i have a -6. The name on the nose is my daughters name. Rory. You will love it.
