rvbldr3170
Active Member
Ok, I am a klutz.
Now that that is over with, does anyone know how to remove Sika primer from the inside of the canopy without using abrasives? I taped off the primer line, but I had the canopy upside down in a cradle to make it easier to work on, and some of the black stuff ran down (up as the canopy is installed) across the tape into the "look through" part of the canopy.
Other than that, I would highly recommend adhesive bonding in lieu of rivets for the installation of an RV-4 canopy
