billdianne Active Member Patron Nov 15, 2013 #1 Trying to remove lord mount. It seems to be stuck in the cup of the motor mount. Is there some kind of trick to removing it without destroying it? Tried prying on it a little bit but don't want to screw it up.
Kahuna Moderatoring Nov 15, 2013 #2 Often times a side load is required. Beating with a mallet. Its stuck but it will come out with enough brute force.
billdianne Active Member Patron Nov 15, 2013 #3 Thanks Kahuna, I guess the old adage " when in doubt get a bigger hammer" has it's place in aviation too.
