pilot28906
I noticed the plastic is difficult to remove and leaves the glue on the skin if the plastic is removed when the skin is cool. Done that this morning and took a lot of MEK to get the glue off a small section.
Later in the day I had the skins in the sun for about 30 min. and the plastic came off easy with no glue on the alum.
I will put the parts in the sun from now on before I remove the plastic.
Thought this might help someone with the same problem.
