When installing the nose tire on the wheel, it says to inflate and deflate a couple of times to at least 60psi, each time removing the valve stem to let it completely deflate. The valve stem is removeable?? how?? How do you then get it back in with the wheel in the tire, ensuring a good seal? I'm tempted to leave the valve stem alone and just deflate the conventional way.
Question, if the nosewheel holds air after a couple of inflating/deflating cycles, can I be reasonably confident that there is no pinching of the inner tube? Or could it be lurking in there, waiting for catastrophic failure on my first landing?
