I want to make the passenger stick removable in my RV-6. Any recommendations on what type of connector to use for the PTT wires?
Thanks!
I did the same. Works like a charm.I used a 4 pin DIN connector. They will fit inside the tube.
Thanks!
An alternative is to move the PTT for the passenger to the panel (or side panel).
I often pull the rear stick in my RV-8 and decided to eliminate the wires all together. The PTT is now next to where the headset jacks are for the passenger.
Mine looks like this:
https://www.dropbox.com/s/5of5q1tkmlj1sx4/Right Stick Cable Connect.JPG?dl=0
Works great with Infinity stick grip... 15-pin DB connector. The actual stick is drilled and tapped for a #8 hex head bolt. Easy to remove...
