Cyclone
Active Member
I'm wrapping up the build project and have a question concerning the Aircraft Registration process. Do I need the packet of forms from Vans including the Bill of Sale and such or can I just download from the FAA, fill out and send to the FISDO?
I checked my AW package. It has three documents with a Vans signature: Bill of Sale, Statement of Conformance and the Affidavit of ownership.
I guess that really didn?t answer your question. I reserved an N number without any of the paperwork I described, and as I recall I needed the bill of sale to complete the reservation.
There are absolutely no "forms" required to reserve an "N" number. A reserved number is assigned to a person, not any aircraft.
You don't have to have an aircraft, a kit, or anything else. Just $10.
If you are going to register as E-LSA, or want to use the kit as a basis for meeting 51% as E-AB, you will need the Bill of Sale from Van?s; but that?s the only form you need from them. The rest of the forms are right here:
https://www.faa.gov/aircraft/gen_av/ultralights/amateur_built/amateur_regs/
In order to register as E-LSA, Vans Aircraft needs to fill out and sign and give to you FAA
Form 8130-15 "Light-Sport Statement of Compliance". Vans will not provide that form
unless you buy every part from them and assemble the RV-12 exactly per the plans.
In order to register as E-LSA, Vans Aircraft needs fill out and sign and give to you FAA
Which is reason I have decided to go EAB. (experimental amateur build like RV-7 and 8 I built) We are getting paper work lined up right now. Have number reserved, waiting on Bill of Sale from Vans.
There is no advantage for me to go E-LSA, you end up with a quasi certified airplane, like a Cessna, very difficult to make any changes.
This is not correct.
An E-LSA is still an experimental aircraft.
True, to qualify for E-LSA you have to build it exactly per the KAI and present it that way for certification.
After certification you can modify it to any degree you choose.
The only limiting factor is that any modification can't make the airplane perform outside of the limitations of a light sport aircraft.
Thanks for the help
I have an N number reserved and initiated the paperwork from Van?s.
Still have some work to finish up along with moving to the hangar, inspection and transition training. I enjoyed the build a lot more than the paper work :)
Any updates on the EAB registration process? Are the operating limitations the same as any other EAB kitplane?
I’m curious on this too. I’m rv-12is with UL350iS engine. I still have to ask vans for my paperwork though. Figure I have about 3-6 months before I’m ready for the DAR.
The registration process for Experimental Amateur-Built aircraft has been the same for quite some time. The manufacturer is "you". You can use whatever "model" and "serial number" you choose. Although, if you build from a kit, the FAA recommends that you use the model and serial number from the kit mfg.
Operating Limitations are Standard across the board for all EAB aircraft.
I don't want to thread drift but what is the practical advantage of E-LSA vs E-AB? Seems like additional restrictions for E-LSA are the only difference?
E-LSA = 5 hr Phase I, vs. 40 hr for EAB. E-LSA = Future owners may obtain Repairman Cert.
Also, I believe E-LSA can be flown with a Sport Pilot certificate. Or is that for airplanes that meet the qualifications, even if not registered as such?
Any aircraft, regardless of classification, that meets LSA parameters, can be flown by Sport Pilot
In addition to the short test period note there is a reason for that. They all fly and handle the same and the systems, controls, instrument layout are all the same within the options. Everything is well documented with manuals, maintenance manuals, testing etc. provided and like it or not since they build S-LSA we have SBs and continuous updates for safety and enhancements. The older RVs were each unique usually in instrumentation, wiring and various engine/prop combinations so much of the 40 hours was spend in working out the bugs. Not really needed with the 12s, flown a half dozen or so and they all fly the same give or take sorting out a heavy wing.
