swisseagle
Hello
I need to redo the engine preservation, because I'm not as fast as I had planed with building.
I have to fill the engine with preservation oil and do a slow roll for a few times, then spray oil into all openings, thats clear so far.
What is more difficult is, to hold/lift an engine and rotate it. So I want to do the following:
- Lift engine at the std. hook and unscrew it from the firewall.
- Support enginemount and engine and reattach engine at the spacer with a sling/crane.
- Rotate the engine by holding the enginemount with up to 4 persons.
Now the question, doe this harm the front bearing, crankshaft or case in any way, because half of the engine weight is lifted perpendicular to the crankshaft?
For sure I will mount a prop adapter and screw the spacer and adapter together!
Thanks for any input, regards,
Dominik
Dominik
