What have others found that works best with their Redcube installation? FWIW My Redcube, on a Lycoming O360, seems to work best with a factor of 66,200 not the 68,000 indicated by the manufacturer.
68000 is a good starting point for the FT-60 (red cube). Depending on what parts were used in the installation (hoses, fittings, etc), an adjustment to the k-factor may be required and is not uncommon.
