Polaroid & near corrections
Long post, but might be helpful to a few.
This seems to be one of the most popular threads and lots of opinions and suggestions. Could it be that our RV pilots don't have exactly perfect eyes when they get older?
Introduction: I'm a government research optometrist for 40 years with a RV-4.
Subject:
Polaroid- Many years ago, we looked at polaroid lens for aviation and found that many windscreens had stress patterns that showed up with color fringes or bifring patterns. Therefore, we still don't allow polarid for military aircraft. HOWEVER, if you've used polaroid sunglasses for driving, for example, you've probably notice a lot of subtle advantages such as reduced reflections from your glare shield. You'll also notice with modern dash and cockpits with LCD displays, the polaroids will reduce their visibility too. When I got a new car (happens about every 20 years), I couldn't see the LCD displays with my favorite clip-on polaroid sunglasses. I outlined the tri-focal from my glasses on the polaroid clip-on, and put the drimel tool to action to remove the near vision area. Here's the results:
http://i614.photobucket.com/albums/tt228/willymac104/Polaroidcut-outsunglasses-1.jpg
From the quality of the cut-out, you can see why I bought my RV-4 already built. On the ground, I checked my vision with the polaroid clip-ons through my RV-4 canopy before I used them for flying, and of course in my new car. There were no color fringes or visible stress pattern through the canopy in any direction. I could see my Dynon EFIS, GPS, and those things in the dark area between my legs such as radio frequencies and transponder better than with or without any sunglasses.
Other notes: The sky is slightly polarized with lines relative to the sun and more noticeable with increase sun elevation. This means clouds and aircraft can change contrast depending on where they are located relative to you and the sun (advantage/disadvantage?). In my RV-4, I've noticed that the front curved windshield (slider) induces a slightly different angle of polarization to the right and left eye. RV-8s should have the same characteristics. In one eye, I may see the reflections from a lake, but not in the other eye. Visually, this means which ever eye has the most contrast, you can see it (advantage). Clouds may have low contrast in in one eye, but will be very visible in the other eye (advantage).
Progressive/standard trifocal: If you get use to a progressive lens, fine. I use a standard trifocal and can walk and chew at the same time. I've had pilots tell me that they would quit flying if they ever had to wear glasses. Poor things. Then there was the story about the pilot with 20/20 unaided that wore corrective lenses to achieve 20/12. Yes, he was a mig killer in Korean war.
Bill McLean
RV-4
LA (lower Alabama)
