I would like to add a second battery in my 9A in the tail cone, as per an old RV7 drawing (OP-16).
I know that this will move aft the CG (and this is the main reason for the installation) and I can obtain the new CG simply measuring the arm from the CG to the battery location (and multiplying it per the weight of the battery).
But since this is a definitive installation, I would like to simulate a new airplane weighting and obtain the weight data for the single wheel (without having to place the airplane again on the certificated scales).
Is there a formula to recalculate the weight per wheel starting from a known weight per wheel and the data of the new installation (arm and weight of the new battery)?
Thanks.
Camillo
Thanks.
Camillo
