steve wyman
Here's a heads up for you guys on page 25-05. Step 5 tells you to tap 6-32 all the #40 matched drilled holes in the roll bar that you drilled in step 3. #40 drill is the correct one to use, because it allows you to cleco the front edge of the window to the roll bar with silver clecos (3/32). However, before you attempt to tap each hole in the roll bar, re-drill it with a #36 drill- this is the correct tap drill for a 6-32 thread. If you don't, you will find that it is very easy to break the 6-32 tap off in the hole- they are notoriously easy to break in that size. In case you're wondering- I didn't break one off, but only because I felt the tap binding and re-drilled each hole #36 as I went along. I then screwed in a 6-32 machine screw to hold everything in place as I went along. Steve
