I was curious, I have a set of preview plans that are older than the kit itself. When drilling the rear spar to match the hs-708 it calls to drill a #19 size hole. Looking at the newer manual it calls for a #21. Which size should I go with? Should I follow the newer plans since clearly adjustments have been made or do I stay the course with the older plans?
