I purchased my 6A kit partially completed and the previous owner didn't leave enough edge distance on the rear spar. I have since replaced that spar and re-drilled the hole. The Fuse Spar was not replaced, so I had to use those holes to guide the drill through the wing spar. I used a drill guide and clamps to keep the fuse spar holes clean.
I came close, but not perfect. The hole in the spar is clean, as is one of the Spar Ears in the fuse. The second spar ear is off just a bit. You can see a sliver of space in the shape of a crescent moon. The sliver is about 1/32 at it's largest and about 1/4 of the circumference .
I was a little worried that in one direction of force, the load my only be carried by the one spar ear. My options are to leave it and move on or drill the hole out to 3/8" I computed the actual distance from the edge of the hole to the edge of material for a 5/8" edge distance. I still have that distance met if I go to a 3/8" hole. However, I would not make the 3/4" edge distance required for a 3/8" bolt. The question is, is this required or is the amount of material specified for the 5/8" bolt good with the 3/8" bolt.
I appreciate your recommendations here.
Larry
Larry
