RVG8tor
I still need to rivet in these anchors and I am concerned that due to the curve of the skin and a flat flush rivet set I am going to get distortion in the skin. I did a search and nothing was found so I am guessing this is a no brainier.
I was also considering back riveting these using the big flat mushroom bucking bar from Avery, I did most of the longeron rivet by back riveting but not the curved parts.
So did most of you use a swivel head flush rivet set? If you used the mushroom bar from Avery to back rivet how did that work.
Thanks for the help
Swivel head
.... and a flat flush rivet set I am going to get distortion in the skin.
I used the same setup as the rest of the aft skin. You will get some distortion in that you are mating a hard flat piece to the curved aluminum. That comes with the territory as it were.
Swivel it is
Thanks for the inputs, I guess I was concerned where I did not need to be. I did put a good radius on the outside edges of the anchors hoping the skin would roll over the edge more smoothly, time will tell.
Thanks again for the inputs
