JDA_BTR
Two of the four holes in my right main gear leg won’t admit the ns1304-29 bolt after a lot of time spent figuring how to clean them out. I think I need to ream then again. Can someone help me identify the correct reamer size. They just won’t work as is. The other side 4 of 4 no problem.
I think the answer is 0.250. Might just take a 1/4 bit and a hand tool to see if the hole will clean out.
