seagull
I added trim to my stick grips and have replaced the OEM trim switch with an on / off (same style) that allows trim control for the right seat stick. I want to re-label the panel trim switch. Has anyone come up with a clean way to re-label the switches short of putting a p-touch label over the top.
Lasered placard
All my interior placards are lasered on a thin self-adhesive aluminum sheet.
Black background with white text. If you want I can send you my AutoCAD drawing files. Looks much better than the OEM labels
Are you referring to DuraBlack Laser Markable Aluminum? Any Pics?
I use a tape label maker with black letters on clear tape. I apply the label and then spray over it with clear satin finish from a rattle can. Clean and permanent.
Matte finish black permanent vinyl and a Cricut (or any other vinyl cutter). Can't tell the difference from the original...
