genep
Member
Re: Creaking nose gear
I suspect I am not the first rv-7a to have a loose/creaking nose gear leg.
I have read all the threads on how to solve this Van's created problem (5/16" drill vs reamer on top gear leg mounting bolt!!) .
Has anyone thought of or tried drilling and tapping the lower ngl socket for a set screw. Maybe even two set screws, one at 3 and one at 9 oclock on the motor mount/nose gear leg socket, lower.
I am concerned that just putting in a close tolerance bolt at the top socket may not be enough. Need some of the torquing moment of the nose gear leg to be taken up by the lower bearing surface, not just the upper.
GAHco has the answer..
He has a reamer and an oversize bolt that works great. Not cheap, be it can be done on the plane. I'm sure he'll chime in.
Good Luck!
Call Me!
Call Me!
And we will yak about your situation:D.
Toll free 888-247-2738
I am at the California Branch, anytime after 8:30am 6/1/09
