Chipper G
Struggling to run the oil line from the bottom of the oil separator to the opposite side of the IO360 M1B. If it runs under the engine it’s way to close to the exhaust. Anyone have any pics of the oil lines?
Here's about the best one I've got during installation.
Nope all your oil pan fittings etc are way different then mine. I have solid intake tubes. Yours has a better oil drain and sump set up for sure but totally different layout then the M1B
Here are a few pics of mine
So running the last oil line is becoming an issue. How close to the exhaust can it be. These will be in fire sleeve
Still needs a little tweaking after firesleeve but basically like this
