Hi All,
Working on my rear window install. I have approximately 1/4" to 3/8" of material to remove along its perimeter where the plexiglass meets the rollbar. Can a random orbital palm sander with 80 grit paper be used here safely? I'd remove material to near the tape line then finish by hand with a sanding block. I've experimented on scrap and its effective at removing material, but the vibration put me off. But then any power tool will have some vibration. Has anyone used this technique, good or bad? Just trying to get through it without causing a self-induced disaster.
Thanks for your time and advice
Scott Davis
Scott Davis
